T56 & hedman long tube headers
Old May 15, 2008 | 11:08 AM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Will i run into any clearance problems swapping in a T56 in my 89 camaro and running the hedman long tube headers? My oil pan will look like this. Thanks for the help.
Old May 15, 2008 | 06:43 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: T56 & hedman long tube headers
Your oil pan won't really matter...
You're going to have issues with clearance at the rear of the trans where the xmember is. I'm using one that has two humps cutout for the exhaust to travel through and tuck up tight. Although I still have clearance problems because of how lowered the car is.
Old May 15, 2008 | 06:51 PM
ssean92's Avatar
Car: sold
I am running the t56 and headmens and no issues, I also am running a canton race pan so that wont be an issue eaither. I wraped he slave with the header wrap and used zip ties to holdit in palce and the zip ties haven't melted so You will be fine.
Old May 15, 2008 | 07:22 PM
heff17's Avatar
Car: 89 Camaro
Thanks for the replys, what crossmember were yall running?
Old May 16, 2008 | 12:42 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Mine is a modified crossmember from a poster on here. 'Drews' I haven't seen him post in awhile but he used to fab them up, paint them and ship 'em out. I welded a torque arm mount to it to pull the mount away from the trans. Kinda like...
I used to have the spohn unit.
It a beefy unit. But the passanger side L bracket that attached to the subframe hung down insanely low and I hit on EVERYTHING. Eventually it ground itself down.
Old May 16, 2008 | 05:11 AM
ssean92's Avatar
Car: sold
I use to use the spohn alo but was way to low. I converted to the Skulte one.http://www.skulte.com/product_info.p...products_id/45
Old May 16, 2008 | 05:47 AM
heff17's Avatar
Car: 89 Camaro
Ok i guess ima go with the skillet. Thanks for the help
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
hectre13
Sep 8, 2015 03:38 PM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
