Diff Swap
Old May 19, 2008 | 05:23 PM
bboivin11's Avatar
Car: 91 camaro rs
Transmission: t5w
Diff Swap
I have a 2001 camaro ss diff and was wondering what it takes to put it in my 91 rs or does it not fit.
Old May 19, 2008 | 07:09 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Re: Diff Swap
It will fit the only issue you will have is if it has traction control and you will have to make the E-brake work.
Old May 19, 2008 | 07:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Diff Swap
And that the fourth gen diff is about 2" wider on each side so your factory rims will stick out.
There's no strength difference between the 2001 and your 91 diff.
Old May 19, 2008 | 09:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Diff Swap
Yep -- for what its worth though, that rear end from that car will have the Zexel/Torsen differential in it, which is a pretty good unit. Its a LSD, but since theres no clutches, it lasts considerably longer and is a bit stronger than the normal LSD in the 7.5".... that part would definitely be worth keeping even if you dont use the whole rear end.
draco
Oct 4, 2015 09:25 PM
ydnar417
Sep 23, 2015 05:57 AM
LittleFranks
Sep 17, 2015 12:22 PM
mddaniel
Sep 8, 2015 05:16 PM
E Rod
Aug 28, 2015 05:17 AM
