Rear end swap question
Old May 24, 2008 | 02:47 PM
jjskibbs's Avatar
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
hey guys, i'm sure someone has an answer here....
i have an '89 iroc 305tpi automatic. 2.73 rear end, i am wanting to go up to maybe a 3.42... i was wondering if i can fit the larger ring n pinion in my housing or if the whole thing needs to be swapped out? any ideas?
Old May 24, 2008 | 03:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear end swap question
Your current gears are on a 2 series carrier. You can get deeper thick gears designed for the 2 series carrier or swap it out to a 3 series carrier allowing you to use factory deep gears.
Old May 24, 2008 | 04:08 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
It would probably be easier to find a 3.08 and numerically higher rear end to put a 3.42 in.. Or maybe find a 3.42 at the junkyard like I did.
Old May 24, 2008 | 05:13 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Just go to a 3.23. Easy swap for any mechanic (you might not want to try this yourself unless you have a lot of know-how.)
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
