where to buy?
Old May 26, 2008 | 03:22 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
where to buy?
my rear differential just went today, so im basically in need of a new one or a rebuilt one, i have an 87 z28 305 tpi with a 700R4, and im pretty sure the gear ratio was 2.73, and i figured this forum would send me in the right direction as to where i can get one
also, just a side note, if i was to run a higher gear ratio like say 3.27 or 3.75 (or 3.73) im sure id notice better acceleration, but is it even worth it to go through all the hassle of trying to correct the speedometer, maybe the computer, or anything else it would mess up (cuz i honestly have no idea, lol)
Old May 29, 2008 | 08:02 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: where to buy?
Do you have posi or an open diff ?
Old May 29, 2008 | 08:41 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: where to buy?
I got my eaton posi brand new off of ebay for 380$ about a yr ago. If you go with a 3 series carrier i'd look into getting 3.42s as well. big difference in acceleration but leaves you cruising around 2200RPM at 65ish.
To correct the speedometer you're gonna need new speedo gears (forget which ones off hand, but its an easy search). One goes on the output shaft, the other goes in the speedo cable housing. You have to remove the tailshaft to get to the output shaft though, so remember that.
Also, before I forget, the eaton posi takes 28 spline axles.
Eaton Posi
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
