Ring and pinion question
Old May 28, 2008 | 09:49 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
All i know about my rear is it is a g80 rear and a 2 series carrier i was wondering if these gears would work for my car without any modification of anything http://store.summitracing.com/partdetail.asp?autofilter=1∂=RMG%2D4900071&N=700+4294925134+4294839047+4294918962+4294791217+4294901296+4294895863+115&autoview=sku
these 2:73 gears just dont cut it for me lol
Old May 29, 2008 | 06:41 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Ring an pinon question
Looks like they are made for the 2-series carrier and will work. However; I would stay away from the Richmound gear. Reason, they cut the gear teeth for racing applications and are quite loud on street car.
Old May 29, 2008 | 01:53 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
ight so just dont get richmond then but any other that say for use in the 2 series is ok? when is say for use in the 3:23 and numericly higher carriers dose that mean really lower numbers or what?
Also would it really be bad on it cause the only ones through summit (only place i like to buy from) are richmond.
Old May 30, 2008 | 01:07 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
If you are going to stay with your 2-series carrier you HAVE to either go 3.08 or lower OR get the "thick gear" (like the one you're looking at from Summit) that works with the 2-series carrier. If you want to run a regular 3.23 or taller gear, you have to switch to a 3-series carrier.
Old May 30, 2008 | 01:59 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
so the one im looking at will work is that what you mean or it wont?
Old May 31, 2008 | 09:41 AM
gcgarner's Avatar
Yes it will work.
Old May 31, 2008 | 09:33 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
ok sweet thanks for the help. how off do you think this will make my speedo? im thinking its gonna be really bad.
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
