overdrive jerk
Old Jun 2, 2008 | 10:13 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
overdrive jerk
got a 2004r and when i'm in overdrive doing 60-70 and I let off and coast I start to get a herky jerky foward-bakwards jerking. I know overdrive will do this at slower speeds becasue the OD was only meant for freeway not around town, but should this be happening when coasting at these speeds?
Old Feb 16, 2010 | 11:19 AM
SpeedyGeek's Avatar
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
Re: overdrive jerk
I'm having this problem too.
Old Feb 16, 2010 | 11:48 AM
Awesome-X's Avatar
Car: 87 Camaro
Re: overdrive jerk
Seems like i may have read somewhere that this might have something to do with the torque converter lockout
Old Feb 16, 2010 | 11:52 AM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
Re: overdrive jerk
i have the same problem except it's at all speeds. from what i've read it is probably the torque converter lock-up. havnt checked it out yet though to be sure.
Old Feb 16, 2010 | 12:53 PM
SpeedyGeek's Avatar
Car: 87 Formula
Re: overdrive jerk
Actually I did a ton of reading today on this. I understand manuals and clutches, I just never read up on how a TC works. Now that I have and read about the lockup, I get it. I also called the shop that put my TC in, he said it just sounds like it's locking too early, at too low of an RPM and I'll need to bring it in to have him adjust the shift points.
The reason this is happening for me is because I've changed everything. New engine, 2600rpm TC, 3.73 gears, no computer, etc, etc. So yeah, adjustments needed :-)
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
