Adjusting clutch engagement
Old Jun 4, 2008 | 08:30 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I read that there's an adjustment screw on the clutch fork, is it okay to adjust the clutch engagement point using this? My clutch engages about 2" from the floor, I'd like to move it up 1" or so, if possible.
Old Jun 4, 2008 | 08:51 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Adjusting clutch engagement
Pretty sure there is no adjustment screw but you could make your master adjustable and move the peddle how far you want.
BTW your bird is missing its wing
Old Jun 5, 2008 | 01:51 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
How would I make the master adjustable? And my car still has the wing for now, but it's not in great shape. My sig is how I plan for it to look :P
Old Jun 5, 2008 | 08:01 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
check that the clutch pivot ball/stud has not backed out . it's the pivot point for the throw out bearing arm . mine backed out , was doing the same thing . it's on drivers side of bell housing , takes a 3/8's allen wrench . clearence is tight but can be done . clean with brake cleaner and use lock-tite before seating/tightening pivot ball/stud . good luck .
Old Jun 5, 2008 | 09:11 AM
Tony89GTA's Avatar
Car: 89 GTA
https://www.thirdgen.org/forums/tran...ghlight=master
Old Jun 7, 2008 | 07:40 PM
UNCLE TOM's Avatar
what have you found to be the problem ? i am curious if your problem was the same as mine .
devilschariot
Feb 25, 2016 03:08 AM
camaro1185
Oct 26, 2015 06:51 AM
sahlomonic
Sep 20, 2015 07:15 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
