PLEASE HELP THIS IGNORANT FOOL TRYING TO CHANGE HIS TRANNY FLUID!!!
Old Jun 7, 2008 | 06:35 PM
FirebirdTKE1128's Avatar
hello-- I need help
I'm trying to change the transmission fluid & filter in my 89 firebird. It has a 700R4. I'm trying to get the drain pan off but can't get to the rear row of bolts because there's a cross member in the way-- do I need to support the rear of the tranny & take this cross member off to get to that last row? It looks like there's a way to slide it back to get to those bolts-- but I'm not sure-- and I need to do it tomorrow morning- PLEASE advise--
thanx
Old Jun 7, 2008 | 06:42 PM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Re: PLEASE HELP THIS IGNORANT FOOL TRYING TO CHANGE HIS TRANNY FLUID!!!
When I take my pan off I just use extension, socket, and a ratchet. I did not have to take the crossmember off when I did my filter change. It was a little tight but was doable. I hope this helps some.
Old Jun 7, 2008 | 06:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's probably possible to get the pan off with the crossmember still in place. When we pulled the pan on a 700R4 in the company 1/2 ton, it was easier to support the tailshaft and pull the crossmember.
Depending on clearance, you may be able to do it without actually pulling the crossmember. Unbolt the tranny mount from the crossmember and lift the back of the transmission. It may give enough room to access the rear pan bolts.
Old Jun 8, 2008 | 01:28 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i just changed my fluid last week and nothing was in the way. i used a 3/8 drive, 1/2'' socket with a 3'' extension with no problem.
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
