i need axle specs
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
i need axle specs
in the market for a locker shafts and a geardset for a friends 92RS. need to know what to order.....
whats the pinion spline, and axle spline and any other info i may need, i know its a 10 bolt but thats it!
thanks
LUKE
thanks
LUKE
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: i need axle specs
27 spline pinion (same as all other 10 bolts, shouldn't even need to ask)
It's a 7.625" 10 bolt, 28 spline axle.
If you're getting a differential, and gears, then you're set.
Car: 92 Rs
sorry about the pinion spline, i knew it before i dont even know why i asked.... haha,
well anywho thanks for your input!
Car: 1982 Trans-Am
oh no no, I just mean if you're buying parts for a 7.625" or even 7.5" GM 10 bolt "they" shouldn't need to ask the pinion spline count, there's only one option.
Anyway, you should have all you need now. If he's making big power, look at a ratech solid pinion spacer, aluminum girdle, and superior brand axle shafts.
