4-speed to TH350
Old Jun 6, 2008 | 06:43 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
4-speed to TH350
My T-10 4-speed is done it makes so much noise you can barely hear inside the car so I am going to swap in a TH350. can anyone tell me what I will need
to go from a manual to auto? I plan on using a B&M mega-shifter and B&M torque arm mount.
Old Jun 6, 2008 | 09:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 4-speed to TH350
Think you have the bulk of it covered.. you'll have to find a dipstick and tube that will fit too. I dunno what will work though, never done it myself. Your driveshaft and crossmember should work though.
Old Jun 6, 2008 | 10:07 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
So now I have two options I can go with the TH350 or a T5? will my 4-speed clutch and flywheel work with a T5? Has anybody used a T5 with a mechanical clutch linkage?
Old Jun 7, 2008 | 02:16 PM
Air_Adam's Avatar
My '83 had a T5 before I swapped to the T10. The clutch and flywheel are the same, they will swap right over. Infact, I didn't even take off the clutch when I changed over to the T10.
'83 T5 cars used the mechanical clutch linkage just like the 4-speed cars. Find a bellhousing and fork from an '83 and it will work with your mechanical linkage.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
