What fluid does an 83 T5 use?
Old Jun 8, 2008 | 01:45 AM
DirtyCanadian's Avatar
two different parts stores said two different things, one said that the tranny uses ATF the other say gear oil, does anyone know for sure what the 83 T5 uses? And what oil do you guys like to use?
Old Jun 8, 2008 | 06:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: What fluid does an 83 T5 use?
Check the sticky.
JamesC
Old Jun 8, 2008 | 04:00 PM
does anyone know off the top of their head?
Old Jun 8, 2008 | 04:03 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
https://www.thirdgen.org/forums/tran...ything-we.html
The 83-87 T5's recommend gear oil for fluid, while the 88-92 T5's recommend ATF.
Old Jun 8, 2008 | 04:06 PM
ok that was the answer i believed but why do the WC T5's require ATF are they that different?
Old Jun 8, 2008 | 04:23 PM
JamesC's Avatar
However, the answer you believe isn't necessarily true. As you'll see when you read the sticky, there are conflicting reports. For example, the manual for my 85, which isn't a WC, recommends ATF.
JamesC
Old Jun 8, 2008 | 04:25 PM
see that must of been whats throwing these shops off
Old Jun 8, 2008 | 10:45 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I say ATF. I know a guy who put 90WT in his T5 and it would not shift.
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
