700R4 bogs in 2nd gear.
Old Jun 8, 2008 | 07:40 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Hey all,
I just got a rebuild 700R4 tranny. I filled it full of fluid and adjusted the TV cable the best I could. (It's a Lokar cable, without the self adjust feature)
When I first put it in gear, it's fine, when it tries to go into 2nd it will bog really bad, almost sending me through the windshield. At this point the engine sounds like it under a lot of stress. If I let off of the throttle, it goes back into first and it's fine. I tried adjusting the TV cable again, and it does the same exact thing. Any ideas?
Is it related to the vavle body or something internal?
Thanks!
Keith
Old Jun 8, 2008 | 08:37 PM
performabuilt's Avatar
Re: 700R4 bogs in 2nd gear.
Sounds like you have a bind up possibly the low roller is locking both ways instead of just one or a cross leak somewhere. But does sound like some internal issue
Old Jun 8, 2008 | 08:42 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Figures.... how far down in the case is this low roller? I have no problem rebuilding an engine, but have slight, to no idea with transmissions... I have a haynes 700r4 rebuild guide... and eyed it over..... then ran scared... lol
Old Jun 8, 2008 | 08:49 PM
Unfortunatly its a complete tear down your n NE PA ? How far from Hazleton?
Old Jun 8, 2008 | 08:55 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
I'm in Thornhurst... no more than an hour and some change....
I didn't notice that you're in Hazleton...
If I pull it would you be able to look at it?
Old Jun 8, 2008 | 08:59 PM
I will ask monday and let you know ok , It would be up to the boss
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
