700r4 early shift @ WOT
Old Jun 13, 2008 | 07:30 PM
MADMAXGTA's Avatar
Car: 89 TTA
tranny shifts @ 4200rpm @WOT ,i did the tv cable adjustment perfectly to spec has show in the tv tech article,I supossedly have a modifed govenor for later shifts,this is the tranny-http://www.bowtieoverdrives.com/cata...m.php?ITEMID=8
What are the stock L98 700r4 shift points?
Old Jun 13, 2008 | 11:27 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
Re: 700r4 early shift @ WOT
check your trans fluid level.
sometimes its something as simple as this.
have car at operation temps.
run the car through PRND321
put it in park and check the level.
Old Jun 14, 2008 | 12:06 AM
MADMAXGTA's Avatar
Car: 89 TTA
I just did the tv cable adjustment agian,followed the instructions in the 700r4 useful info thread,its a little better 4700from 1st to 2nd,but 2nd to 3rd was only 4200,and i seem to have a flat spot @4000 in 3rd,gets ther quik,hangs out @4000rpm for a split second,then carrys on...idk
I checked it out,its full.
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
