Roller Pilot Bearing removal
Old Jun 15, 2008 | 09:37 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I cant get my pilot bearing out.
I have tried the pack with grease, but the grease flows past the roller bearings and around the dowel shaft. I have used this method sucessfully in the past on a solid bearing.
I rented a puller tool today and it did not work either. I may modify the tool th make it bite harder.
Anyone with any experience.
Whe I get it out a solid unit is going back in.
Old Jun 16, 2008 | 07:23 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Roller Pilot Bearing removal
I just did the same thing a couple weeks ago. I also tried the grease method, which didn't work for me either. I used a slide hammer to pound the bearing out and eventually it came out.
Old Jun 16, 2008 | 09:21 PM
SDIF's Avatar
Thanks,
I used the slide hammer case closed
gixxer92
Sep 1, 2015 04:32 PM
TEEZER TA
Aug 30, 2015 06:35 PM
19irocz85
Aug 26, 2015 07:54 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
