How to find out what type rear end I have?
Old Jun 19, 2008 | 04:38 AM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Hi there..
I have a plan on changing my gears in my 87 Camaro Sport Coupe.
But how do I find out wich kind of rear end I have?
I know that the gears is 2.73 now on my car and I was thinking of changing in to 3.43 gears.
But to change the gears I need to know if it is a GM7,5" or 8,5" or higher??...How to find that out?...Serial number mayby?
Old Jun 19, 2008 | 05:54 AM
phoxetis's Avatar
Car: T/A
Engine: 5.0 v8 TPI
Re: How to find out what type rear end I have?
I think the best place to start is to count the bolts.
If you have 9 bolts, you've got a Borg-Warner, if you have 10, you've got a GM. Both need completely different parts.
If you are sure you have a 2.73 ratio, you probably have a GM.
Old Jun 19, 2008 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No thirdgen car is equipped with an 8 whatever. Do a search on carriers (series II and III) before you do anything else. Also note that you'll have to swap the drive and driven gears to make you speedo register correctly.
JamesC
Old Jun 19, 2008 | 08:30 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
In 87, only the IROC-Z cars had the 9 bolt option. All the other models had the 7.5" 10 bolt.
According to the TGO data list, the 87 Camaro SC only came with a V6 which has 3.42 gears. All the other A4 cars have 2.73 gears.
Old Jun 19, 2008 | 03:02 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
Transmission: 5 Speed
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
Unless it has an over the counter Dana 44 8.5"
Attached Thumbnails How to find out what type rear end I have?-picture089.jpg
Old Jun 19, 2008 | 03:59 PM
I agree to that the SC came with a V6 but it also came with a 305 engine if you wanted some extra power on that time...So my car have stock 305 engine with 700r4 transmission.
I am pretty sure that my car have 2.73 gears since the engine is running about 1400rpm - 1500rpm in 60mph...
Old Jun 19, 2008 | 06:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
If it came with a 305 then it's not really a SC but a SC/LT. The LT option gave it the 305.
The LT has a 165hp 305 and 2.73 gears.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
