9 bolt carrier?
9 bolt carrier?
How do I figure out witch carrier I have and I have not pulled the cover to find gear ratio yet but from what I read any thing higher than 2.7 would be the 3 carier is that correct ? thanks
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: 9 bolt carrier?
the ratio will be stamped on the side of the ring gear. the only ratio that is in common with GM ratios is the 3.08 and you can use that if you can find one. most common are 2.77 and 3.27. 3.45 ratios are hard to find. 9 bolt.com has parts if ya need them.
Re: 9 bolt carrier?
my quistion is I found the 9 bolt.com site and they talk about the 2 series and 3 series how do I now witch I have becuse I want the 4.11s but it says I need the 3 serious diff so I was just wondering if I need to buy that aswell
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: 9 bolt carrier?
believe it or not a 3.08 is a 2 series, why i'll never understand but it is. so you need to find a 3.27 ratio or better. i wish they would do like some companies and make a 2 series carrier that are designed to run 3 series gears.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 9 bolt carrier?
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
