Can someone explain why some crossmember mounted torque arms are like this?
Old Jun 21, 2008 | 08:26 AM
Parts4sale's Avatar
So what does this peace do below just the rod end? Is this made to allow correct movement of the rear end and rear suspension travel Vs a fixed rod end? Can someone explain why some crossmember mounted torque arms are like this?
Old Jun 21, 2008 | 09:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Can someone explain why some crossmember mounted torque arms are like this?
The torque arm needs forward and backward movement also. Look at the factory mounted torque arm. It's designed to slide in the bushing. That's also why you have a slip yoke in the transmission.
There's an early design that had a fixed mount but had a slip tube design. This had a protective dust boot and needed to be greased.
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
