First time changing Rear Axle fluid so i need help
Old Jun 21, 2008 | 01:39 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Well I'm about to go and drain the fluid and really have no idea of
- What kind of fluid to get
- How much fluid to get
- Do i need any additives(i saw some posts saying they added additives) if so what kind?
- I have a torque ratchet, what PSI shud i set it at?
- Do I need a gasket?
The car is a 90 Camaro RS. Stock Rear. Going by the Tech Database it's 3.23's.
Old Jun 21, 2008 | 07:43 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: First time changing Rear Axle fluid so i need help
80/90 gear oil. I would get 3 qts.
additives would be needed if you have a posi rear. If so, Get friction modifier.
You dont get a gasket, you can use RTV, but a gasket would be more professional. You dont have to torque the bolts just do tighten the bolts till the touch the cover, and then maybe 1/2 turn more.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
maroe624
Apr 16, 2017 08:29 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
