5 spd
Old Jun 24, 2008 | 03:37 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
5 spd
hi guys i was wondering if you might have any ideas with whats going on with my tranny. if im in forth gear it will not let me go straigh back down to third. i have to put it in second then third . any ideas?
Old Jun 25, 2008 | 09:31 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
Re: 5 spd
my wc t5 does the same thing i have no other problems so im not really worried, might be early syncro trouble but im not sure, if anyone knows for sure i wouldn't mind knowing hehe sorry not much help, i have a pro50 shifter and changed the fluid and that didn't change it
Old Jun 26, 2008 | 12:41 AM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
Re: 5 spd
yeah mine has no other problems either but there has been times im in forth and someone wants to take off i cant follow because i got to go back to second lol thanks ne way lol
Old Jun 29, 2008 | 07:42 AM
Pat Hall's Avatar
Re: 5 spd
Sounds like a slider hub problem to me. A common cause of this is a broken or missing key between the slider and hub. This causes the slider to be able to move freely in one direction, but jam up going the other way. There's usually 3 of these keys that rest in slots in the slider hub. They commonly break in half or fall out altogether, which causes the slider to bind up when trying to shift. Another possible cause could be really worn engagement teeth(the small teeth) on 3rd gear. These teeth are what locks the slider to the gear. Most often it's the keys though. The keys are a common failure point in the T56's since they're made of cheap, cast metal. They're commonly replaced with billet steel ones when one is built up for performance.
Old Jul 10, 2008 | 08:08 PM
DM91RS's Avatar
Car: 91 RS
Re: 5 spd
Glad I read this as mine will no longer down shift into third. For years after I first purchased the car I could actually down shift very fast in all gears. Gotta fix this as I think it sux when one knows how it should be.
Hawk312
Aug 22, 2017 08:55 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
Dquickshift
Aug 12, 2015 06:21 PM
