overdrive trans to a turbo 350
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Hellol, i have an 84 firebird with an overdrive tranny im switching it to a turbo 350 3 speed auto matic. My question is will i have to change out the cross member?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: overdrive trans to a turbo 350
The TH350 mounting pad is 2" forward of the 700R4 position. An adapter plate can be fabricated to make up the difference.
There's a kit available to make the swap easier. It includes an adapter for the mount and an adapter to install the torque arm on the tranny. Although this is a cheap and easy way to do the swap, it's better to buy an aftermarket torque arm which will come with a proper crossmember. The aftermarket torque arm will mount to the crossmember and not the tranny.
The TH350 will also need a manifold vacuum source for the modulator valve.
theshackle
Sep 17, 2020 08:26 AM
