26 or 28 spline?????
Old Jun 29, 2008 | 08:44 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
how can I tell
I dont know the year
do i have to take out an axle
Old Jun 29, 2008 | 09:58 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 26 or 28 spline?????
What year is your car. Assuming the diff or axles have never been changed, 82-89 will have 26 spline axles and 90-92 will have 28 spline. 89 is a changeover year and if the car was built late in the production year, it "may" have 28 spline axles.
There's an axle code on one of the tubes to help find the year. If you can't find the year, you need to pull axles and count the splines.
Old Jun 30, 2008 | 02:55 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I noticed in your profile on the left it says 9-bolt 2.77, all 9-bolts have 28 spline axles, and you can only use 9-bolt axles with them. You cannot use 10-bolt axles.
Old Jun 30, 2008 | 08:53 AM
jamon8's Avatar
Engine: 350 tpi
this is a rear end that I have sitting on the side of the garage
I took a long trip and then my rear went out so I got one at a junkyard and put it in
made for a great vacation
I have a cutlass that has a 2.14 yeah never heard of it before but the ring says 47:22
I want to put the carrier and the pinion from the junkyard rear into the cutlass but the only way I can do it is if the axles are 26 splines on the junkyard rear
I am not going to spend the money to get 28 splined axles for the cutlass
after all the blah blah blah I do have a question
where can I find the numbers on the axle tube and how do I use them to find out if I can use the carrier
Old Jun 30, 2008 | 02:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I don't think the diff from the cutlass is a 7.5" 10 bolt especially if it has 22 pinion teeth. Normally pinion teeth are in the 7-11 range. Depending what year it's from, it may be a 8.2 or 8.5" 10 bolt.
Axle tube numbers are stamped on the front of the passenger side tube. They're always hard to read.
Third gen axles will only fit into third gen diffs. No other 7.5" 10 bolt has the same length axles as a third gen.
Old Jun 30, 2008 | 05:54 PM
jamon8's Avatar
Engine: 350 tpi
so you are saying that I might have a rear end that I could use the carrier out of a 1st and 2nd gen camaro or firebird
I was going to use the carrier out of the firebird rear on the side of the garage along with the pinion and put it in the cutlass's housing
I will take a wire wheel to the front of the pass side of the axle tube
codeysabatini
Nov 10, 2015 04:07 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Numbah-1
Sep 20, 2015 09:31 AM
Prodigious
Sep 18, 2015 05:23 AM
