trannie temp gauge
Old Jul 28, 2000 | 05:42 PM
87formula350JJS's Avatar
trannie temp gauge
What do yah use to install a trannie temp gauge? Where does it hook up to on the trannie? I really like the setup that has the gauge pod on the window rail and would like to intall one any help is appreciated thanks guys!!
flowmaster,afpr,coolant by-pass,ex.cutout,ported plenum,hyp.chip,cold air intake,airfoil,mod.maf
160 thermostat,hyp tech fan switch, B&M shift Kit,
Old Jul 28, 2000 | 05:54 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
You will need a temp manifold (T-block for flared end tubing) and extra wire (I used color coded). The gauge will come with the sender and misc. gauge stuff. You need to mount it in-line of the trans cooler lines (or you can use the pressure check port on the driver's side of the tranny, like some have used). I mounted a cooler as well with the gauge, plus I mounted the temp manifold on the return line. So I can tell if my coolers are working. The guage will show ~160'-180' most of the time, except in drive at a stop (it will climb slowly to ~200'). HTH
George P. Lara
1984 Z28 High Output
Proud Member of SCFB
V6 T5 For Sale
Old Jul 28, 2000 | 06:01 PM
I really don't know what you mean when u say a temp manifold what is that? So you mount it in line with the trannie cooler?
Old Jul 28, 2000 | 11:59 PM
can some one answer this?
Old Jul 29, 2000 | 02:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's more or less how he described it, a T-fitting that screws in between one of your cooler lines and the transmission, and the sender screws into the 'T' part.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
86IROC112
Sep 11, 2015 04:04 PM
