BW 9 bolt Q&A's :D
Old Jun 30, 2008 | 12:05 AM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
BW 9 bolt Q&A's :D
here i am again with a 9 bolt situation.
has anyone ever done axle seals on a 9 bolt.
apparently my guess was wrong. and its not held in by C-clips like your generic differentail.
can some one walk me through on this one please?? fluid is pissing out of the left rear seal..
thanks!!
Old Jun 30, 2008 | 01:10 AM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Re: BW 9 bolt Q&A's :D
Nothing to it. The seal on the 9 bolt is basically a big O-ring. Take off the four axle flange retainer nuts, slide the axle out, pull the old seal off, slide the new one on, reassemble. The seal should be a common auto parts store item.
Old Jul 25, 2008 | 05:20 PM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
You will need a slide hammer and adaptor to take the axles out. Then you will need to have the bearings removed and pressed back on at a shop.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
