WHAT TRANS DO I NEED 4 MY 84 Z-28
Old Jun 30, 2008 | 01:58 AM
lilred406's Avatar
Car: 1980 & 1984 camaro
Engine: 80 camaro bbc & 84 Z-28 406sbc
Transmission: 350 trans
Axle/Gears: 4.10 gears
SHORT OR LONG TAIL SHAFT??
Old Jun 30, 2008 | 03:35 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: WHAT TRANS DO I NEED 4 MY 84 Z-28
What trans are you trying to put in? IIRC, short tailshaft TH350 is the normal "car TH350" and the long tailshaft TH350 is the same length as a 700R4. Hope that helps. 700R4 would have been stock in an '84 though.
Old Jun 30, 2008 | 09:37 PM
lilred406's Avatar
ok, i need a long tail 350 then?
Old Jul 1, 2008 | 05:34 PM
Air_Adam's Avatar
Maybe... I'm more familiar with the manual trans that came with these cars. Wait for someone else to chime in and see what they say.
Old Jul 5, 2008 | 03:05 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
If you are planning on putting in a TH350, then you will need to get a torque arm mounting kit which are REDICULOUS in price at right around $100. A person could easily build there own for pennies or nothing at all if they had a welder and some scrap steel. JMO
Old Jul 5, 2008 | 07:48 PM
squeeezer's Avatar
Car: 5 cars
the t5 5 speed and the 700r4 use the same driveshaft=fact
this means they are the same length
the swap you wish to perform must be a thm 350 cause they are the only trany i know of for your options (GM) with either option
short shafts are more desirable
long shafts are plenty strong and if you wana save some money by not purchasing a new driveshaft
then yes get the long shaft thm 350
and your driveshaft will slide right in
Hawk312
Aug 22, 2017 08:55 PM
tom1985
Apr 19, 2016 07:55 AM
louishenry
Aug 28, 2015 09:41 AM
zayne0
Aug 24, 2015 07:22 PM
Hello, Michael
Aug 20, 2015 03:19 PM
