168 tooth flywheel and a 5 speed?????
Old Jul 5, 2008 | 09:36 PM
racechevy7's Avatar
Can I use a 168 tooth flywheel with my 1991 5 speed? I can get one that uses the 10.5 in. clutch which I believe is what my tranny has. My problem is finding a starter to match my engine and tranny application. i.e. offset bolt pattern and 153 tooth flywheel. I believe that offset starters for a 168 tooth flywheel are pretty common, and does anyone know if they will have any clearance issues with the bellhousing? Thanks
Old Jul 5, 2008 | 10:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 168 tooth flywheel and a 5 speed?????
No, it won't fit the bellhousing.
gta892000
Aug 11, 2019 11:16 AM
Stangski09
Nov 14, 2015 01:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
dimented24x7
Sep 17, 2015 06:58 AM
roysatikas
Sep 7, 2015 08:08 PM
