Torque Converter
Old Sep 10, 2000 | 10:44 PM
ChevypickupTPI's Avatar
Torque Converter
How do you know when your torque converter is goin out or has totally gone out? Becuase i have a th350 that wont do anything. doesnt even have reverse. i was told that if it was a borken sprag it would have reverse. Plus before it totally went out it was making a noise like wet shoes on a tile floor, when the tranny was cool if that helps any.it would only make that noise in reverse or drive not while it was just idling. Please help.
ryan
[This message has been edited by ChevypickupTPI (edited September 10, 2000).]
Old Sep 10, 2000 | 11:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You may have done some damage. After the first race of the season I destroyed the sprag in my TH350. I didn't realize it until after the end of the second race. During the second race I had no manual 2. Putting it in drive, it only shifted twice. Finally I had no forward or reverse. When I pulled the pan I saw the parts from the sprag. A piece got into the pump and seized it up also preventing hydraulic pressure to move the car. As soon as I lost power I shut off the engine. It's a good thing because without the pump working I almost seized the converter shaft to the pump. It's possible that you've done the same thing. I picked up a used tranny from the junk yard and switched over all the hard parts that I broke. The clutches were still new so I reused them. It cost me $50 in parts to fix it and I ran the rest of the season with this quick rebuild.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
