Bullet proof T5????
Old Sep 12, 2000 | 10:42 AM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
Bullet proof T5????
I remember hearing discussion about a bulletproof T5 in the past. Now is this just a Tremec 3550 or TKO?? Does anyone sell upgraded internal parts for a T5? Like gears and syncros?
1986 CAMARO Z28 -> 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, reinforced LCA's, Subframes connectors, front LCA poly bushings, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.16@ 107.1MPH Next mods-> Lowering springs(have not installed yet), adjustable panhard rod, LCA lowering brackets, homemade ram air, B&M shifter.
Old Sep 12, 2000 | 10:53 AM
Get Blown ?'s Avatar
There is no real upgrade for the T5. There's Counter Gear Stabilizer upgrade you can buy and that's about it. Checkout www.5speeds.com and http://www.fordmuscle.com/archives/2...t5/index.shtml
Here's the trans ratings
BW T5 rated at 265 ft lbs
BW WCT5 rated at 305 ft lbs
Tremec 3550 rated at 425 ft lbs
Richmond 6 speed rated at 450 ft lbs
ZF6 rated at 450 ft lbs
94-97 T-56 rated at 450 ft lbs
Tremec TKO rated at 525 ft lbs
My car is the perfect women. She's braless, won't talk back and loves a good beating.
1989 Camaro RS L03 w/ WC T-5
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Sep 12, 2000 | 11:04 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I have an 86' Z28 with the 3.35 first gear. What is the torque rating for the trans? Is it 300lbs? I have about 375 and it holds up pretty good.
Old Sep 12, 2000 | 02:29 PM
All 87 and under T5s are rated at 265 ft lbs. Internals between worldclass and old T5 are not interchangeable 88+ are worldclass.
That's not to say a T5 won't handle more then what they're rated at. As long as you don't abuse a T5 it will survive. Chuck E. had a WCT5 behind a 383 for over 2 years and it survived. But you throw on slicks and powershift it your just asking for trouble.
GTAman
Jul 3, 2024 07:29 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Logan Bryant
Sep 18, 2016 09:27 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
69 Six Pack
Oct 5, 2015 07:51 PM
