Clutch Q....
Old Sep 12, 2000 | 07:25 PM
B L A D E's Avatar
Clutch Q....
My gears dont engage until the pedal is almost all the way out (towards me) and the gears disengage quickly when I hit the pedal... this is normal, right? Or a sign of wear on this new clutch already?
Old Sep 13, 2000 | 10:56 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey BLADE, that would be normal since that NEW clutch assembly is so thick, the slave cylinder doesn't have to move far to release or engage. My CLUTCHNET KEVLAR/CARBON FIBER DISC with new PP did the same thing. This enables lightning fast shifts when the assembly is so new. Unless something is GRINDING or the clutch ISN'T working, it should change to what your more accustomed to once it starts wearing more. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Sep 14, 2000 | 08:43 PM
84FTA's Avatar
Sounds normal to me aslong as your clutch isn't slipping noticably under high loading.
'84 Trans Am
Crate 350 - 4 bolt main, Holley 600 w/vac. secondaries now open element
T-5 - Stock with Zoom clutch and PP
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
