shift knob removal on the 700 r 4
Old Sep 17, 2000 | 10:54 AM
Rick's Avatar
shift **** removal on the 700 r 4
need to remave console. do yo need to remove the **** or do you unbolt the whole stick from its base.
91 Z28 BLACK WITH RED INT. 350 WITH AUTO
BEST TIME 14.76
K+N WITH MODIFIED AIR BOX
PORTED PLENUM
91 Z28 RED WITH BLACK INT. 305 WITH 5 SPEED
BEST TIME 15.00
ALWAYS AROUND FOR CAR AUDIO QUESTIONS
MOBILE ILLUSIONS/
CERTIFIED MECP PRO
CUSTOM 10" SUB BOXES
http://sites.netscape.net/ratherick/homepage
Old Sep 17, 2000 | 11:35 AM
admrlam's Avatar
All ypu need is a flathead small screwdriver.... There is a u shaped clip sticking in the front of the ****, facing the radio... Once you pry that out, the **** just slides right off the shaft... (had to replace my console with a 91, so i could have the actual shift indicator, instead of just the lights)
1988 Formula, 305TPI, 700r4(for now), headers, stage 2 PROM, modded MAF, cat back, no catalytics, cowl hood, centerline champ 500 rims, KOBEL predator ground effects kit, Trans AM tailights, dash pouch, 92 shift console w/indicator, white face gauges, accented red trim, 12 speaker stereo, 4 amps, tint, T tops... icq 44373460 AIM:admrlam
see it at www.geocities.com/admrlam/bird.html
Old Sep 17, 2000 | 12:47 PM
Rick's Avatar
Old Sep 17, 2000 | 06:16 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Put the transmission in first gear and it will make it much easier to see the small "C" clip you have to remove. It's a piece of cake then. Good luck, Lon.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
