Will a 4th gen z-28 or firebird equivelant rear end fit into a 3rd gen?
Old Sep 19, 2000 | 03:05 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I was planning on changing my gears to 3.77, but why spend the money if i can get a fourth gen rear end with posi grip, 3.42 gears and disc brakes? Oh, do all fourth get z28's come with posi?
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter-the best mod so far
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph with traction problem. Have to try again sometime.
Old Sep 19, 2000 | 03:26 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
The 4th gen rear end is wider than the 3rd gen's. As for all of the suspension mounts; lower control arms and panhard, they are the same. Yes, I believe all of the 4th gen z's come with a limited slip differential.
Neil 383 IROC-Z: TFS heads/JE pistons 10.8:1/ 24lb/hr SVO inj./ Edelbrock Runners&Base/ Strange 12Bolt Diff./ Neil's Home-Built BulletProof 700R4+Vigilante 2800 stall converter & much more.........
Old Sep 19, 2000 | 05:34 PM
Dan84SC's Avatar
Yup, 4th gen axles are wider. I had one for about two weeks, then resold it because of the backspacing issues. I don't want to run fourth gen rims, nor do I want third gen rims to stick out on the back of my car.
Just get a 3rd gen 10-bolt, and rebuild it.
Old Sep 19, 2000 | 10:15 PM
import'sdread's Avatar
remember, a good amount of third gen's came with rear disc brakes and limited-slip diff's. My '89 Trans Am has both.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
