will i notice much going from 327 to 373 gears?
Old Sep 20, 2000 | 01:25 PM
bad camaro RS's Avatar
is it worth it with my mods in my sig
1992 camaro RS
327 posi 9 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 7/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
Old Sep 20, 2000 | 02:31 PM
MrJ's Avatar
MrJ
That's kind of an odd way to upgrade.. you swapped out the stock 10 bolt rearend for the 9 bolt, but now you want to go back to the 10 bolt again, so you can run 3.73s?
As to whether it's worth it, probably not. 3.27 is a pretty decent ratio to begin with, and with the steep 1st gear in the 700R4, all it's going to do is hurt your traction and give you maybe a tenth or two. You are still using long runner TPI, so you probably aren't making all that much top end HP.
91 Trans Am WS6
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
MoreMoodThatMod
1nastygta
Oct 28, 2015 08:51 PM
Mickeyruder
Sep 2, 2015 02:45 PM
someone972
Aug 30, 2015 12:52 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
