Posi rebuild
Old Sep 17, 2000 | 06:41 PM
88 GTA's Avatar
Posi rebuild
Is it possible to rebuild my posi unit? It came out of an 87 10-bolt.
dave
Old Sep 17, 2000 | 07:45 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Yes it is. I did it on a second gen 10 bolt a few years ago. I believe the clutches were around $90 from the dealer. While I was at it I reaplaced the axl seals at the end of the shafts and inspected the bearings for wear.
The headest part was getting the spider gears lined up while inserting the tentioning mechanism and alignment pin. I narrowly averted a nightmare when the bolt holding the alignment broke. Luckily the remaining piece was loose enough to get out with a screw driver.
Good Luck!
Old Sep 18, 2000 | 01:12 AM
88 GTA's Avatar
Thanks for the warning!! I'll call around for prices.
dave
Old Sep 21, 2000 | 01:11 AM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
The 10 bolt in 2nd gens and thirdgens are completely different and the limited slip units in third gen 10 bolts are not servicable except the early 80s Eaton posi units which are not any good anyway.
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
dbrochard
Jan 28, 2016 08:42 AM
NZKnight
Oct 15, 2015 02:47 PM
Giocio
Oct 1, 2015 12:20 PM
6998poncho
Sep 25, 2015 02:56 PM
Prodigious
Sep 18, 2015 05:23 AM
