question on gearing..3.27 vs 3.55 vs 3.73 help!
Right now i have 3.73 gears in my car. The top speed in third gear at redline(has 700r4) is about 100mph give or take a mph or two. i hit this speed at the very end of the 1/4 mile. would my car run faster e.t's with 3.55 or 3.27 gears, allowing me to stay in first and second gear longer or is this the best setup?
Also anyone know of a way to shift into overdrive at full throttle? are there any parts available that allow this?
thanks
thanks
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you have a 10-bolt with 3.73 gears, the next step down is 3.42's I believe. If you get your car running faster in the 1/4, you'll need a taller tire, or less gear.
B&M makes the kickdown cable for your trans. You'll have to search for it, as I dont know the part number.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 4
Engine: 6
Transmission: 5
Probably not, if the car is still accelerating at the traps.
What is this "redline"? Is it just the trim paint on your factory tach? If so, that's altogether meaningless as far as how to set it up for racing.
What is the motor?
What is the motor?
hectre13
Dec 11, 2023 08:14 AM
