Will spider gear failure cause damage to..
Old Sep 25, 2000 | 02:45 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
my ring&pinion?
This thought just occured to me, I swapped to richmond 3.73 ring and pinion, but the spider gears are still stock in my open-end diff. Now as long as there is plenty of tire slippage will my dif hold up? or is that a stupid newbie question?
I mean i wont be running it extremely hard all the time, but if the spiders go, can they cause internal damage?
I am making close to 400hp and my spider gears wont be replaced until I get a powertrax locker. what else might fail? I've had the whole dif rebuilt, bearings and all.
any thoughts?
thanks,
Jeremy
Old Sep 25, 2000 | 08:34 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I've busted spider gears twice before..once in a 10 bolt Dana 44 rear, and a 12 bolt GM rear...both times I was lucky I guess, the chunks stayed low in the housing.
It is possible that they could get inbetween the R&P and do some damage, but it wasn't an issue in my cases.
Old Sep 25, 2000 | 09:19 PM
ede's Avatar
ede
i had a friend break his spider gears and they got his ring and pinion, depends on how bad it gets and how quick you stop the car. he never stoped when he heard the noise
ICON MOTORSPORTS
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
roysatikas
Sep 7, 2015 08:08 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
