What are my choices, rearend slop
Old Sep 26, 2000 | 08:59 AM
redmet91z's Avatar
I'm having a problem with the rear diff on my 91 z. Sometimes it makes clunking noises at very low speed and when I backup. I took my car in to have the exhaust welded after I replaced my fp. I had the guy check my u-joints and said they looked fine but I have a lot of slop in the rearend. He turned the rear wheel and the diff made a noise. So never having messed with a rearend before I don't know what my options are. Should I just get a new rearend? Do I need a new posi unit? Anyone have experience with this?
1991 5.7L Z28 - gutted air boxes, K&Ns, airfoil, ported plenum, relocated MAT, accel base, accel 300+ ignition, walboro fuel pump, holley AFPR, vette servo ,flowmaster exhaust, and a custom chip. More to come!
Old Sep 26, 2000 | 07:44 PM
ede's Avatar
ede
the cheapest and easiest way i ithnk would be for you to get a used rear from a salvage yard and swap it your self. draw back to that is you may get differant gear ratios, may lose posi, or get a posi. other option is you can rebuild (or have someone ) rebuild you rear end.
-=ICON MOTORSPORTS=-
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
