Plan to install new valve body...any suggestions?
Old Sep 28, 2000 | 11:14 AM
86Trans Am's Avatar
I have limited tranny experience, just change the fluid and filter and thats about it. How involved is installing one of these valve bodys that allows the car to shift into 4th at WOT? At the track, i'm redlining before i get to line in 3rd, does anyone think this valve body change would help it out or hurt? Not that i am doing it souly for the track, but just wondering.
thanks
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Sep 28, 2000 | 06:32 PM
84FTA's Avatar
You'll need to watch the checkballs and make sure you don't loose any. They'll all fall out when you pull the valve body. Some go in the top half and some go in the bottom half. The directions should have picture locations of check ***** if not I still have some. It's not all that hard to remove and install a valve body, just get assembly lube to hold the check ***** in place.
'84 Trans Am
Crate 350 - 4 bolt main, Holley 600 w/vac. secondaries now open element
T-5 - Stock with Zoom clutch and PP
Old Sep 28, 2000 | 06:36 PM
85ZZ4TPI's Avatar
I just did art cars shift kit and fourth gear sleve, If all you need is the sleve and no shift kit its not too complicated. Shift kit needs a little know how.
Old Sep 29, 2000 | 10:43 AM
86Trans Am's Avatar
If i can assume you remove the pan, generally, what comes next? What else comes off in order to remove the old body, is there anything that needs to be properly aligned, besides the checkballs, is there anything else to watch out for?
I guess the main question is does the valve body come with comprehendable instructions? I know how some of these parts instructions are.
thanks
1986 Trans Am
305 TPI
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
NinjaNife
Aug 23, 2015 11:49 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
