to all those with 373 gears
i went from 327 to 373 gears i have a few questions
1.you think ill see any gain in 1/4?
2.have any of you got your speedo to read right? whats the easiest way to get it to read right?
3.what do you guys shift at?
4.what do u suggest i shift at with my mods?
5.you think ill be"out of breath"by the end of the 1/4 with the 373 gears?
thanks in advace
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
thanks in advace
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
yes i think you will see a 1/4 mile gain. as far as "being out of breath" at the end of the 1/4...that depends on how high your car makes power and what your redline is. i have 3.73 and my car is DEFINETLY out of breath, but i can only rev the engine to about 5200-5400 rpms(about 200 to 400 OVER redline stock). you'll probaly be ok since your car has a 350 vs my 305.
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Depends on how much power your making, if your making close to 300hp you will probably be outa revs before the trap.
as far as shifting goes, do a few runs and see how it acts when you shift before, at and maybe a wee bit over redline.
I think you can simply pickup a new speedo sensor for your trans and dif ratio from a GM dealer.. I think??
I hope so, i havent gotten my speedo fixed yet
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
On August 24th, I was sitting in the 5000 RPM range of third gear when passing through the traps at 100 MPH.
I have 3.73's and a 305 L69 engine.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
New best E/T! 14.400 at 98.6 MPH in 88 degree air at Stanton, Michigan.
Daniel Burk
They will tell you the right gears for your speedo in the tech articles here on thirdgen. That is where I got the information on mine. Check it out.
Eric
Teal 1991 Camaro R.S., T-Tops,
Leather, Re-worked 700r4 also w/kit,
MSD ignition, MSD 8.5 mm. superconductor wires,
MSD Coil, ADS superchip, Open element air cleaner,
K-n-N filter, Gutted cat, Flowmaster cat-back system,
Edelbrock TES headers, March 3piece billet underdrive pulleys
3.73 gears
http://www.geocities.com/gitarz2/camaro.html
I was shocked to see that companies sold a taillight
set for a rustang! Since when do they have taillights????
Eric
3.73 gears
UltRoadWarrior9
Sep 2, 2015 08:24 PM
