Need good advice on manual swap for 460hp '91
Old Jul 14, 2008 | 08:26 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Was wondering who has done or has good info on where to find a T-5 swap out tranny for my 91 z28....the car has around 460 hp and gets run hard...i DO NOT want to run a stock T-5.....and don't really want to run a t-56 (unless that's only choice), I would like a T-5 that can handle the power and need a website or phone number of a business that builds or sells 5-speeds for a third gen......any info though would be helpful...thanks guys.
Old Jul 15, 2008 | 06:01 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Need good advice on manual swap for 460hp '91
it's not drop in, but tremec might be your only 5 speed option.
Old Jul 15, 2008 | 06:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
gforce sells a t5 with an upgrades case that is "supposed" to be good for the power, but people have mixed experiences. One guy on here 5678TA, has an and it running 11's with no issues, but at a price of 2500+ bux, its a better bet to use a tko600 if you want a 5 speed. Its about the same price but a much stronger trans and it will hold the power. Other than that its a used low mile t56 and swap parts, though its only rated for 450 ft/lbs from the factory.
Old Jul 15, 2008 | 07:58 PM
Engine: L98 494hp
do you guys have a website adress for these tranny's i can look at....i was hoping not to spend a butt load, but just want a manual bad for some reason.....i looked into doing a t-56 swap but cutting the torque arm and driveline, moding the crossmember is not really what i want to do..plus i'm never done adding power so the 450 hp on the six speed might not hold up down the road.....also if i am correct aren't the gear ratios in the t-56 really tall, calling for different rear end gears to compensate (which i just had a new rear end built and don't want to do it again either).....let me know what you guys think
Old Jul 16, 2008 | 12:20 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I have a T-56 in my car, stock driveshaft is still there (well, aftermarket aluminum, but stock length) the torque arm is still stock and bolted up fine. The crossmember is the only thing that had to be cut/ made.... The trans. tunnel needed to be trimmed a bit, but it was simple. I had a 700r4 in the car when new, then changed to a T-5, now I am running a T-56...
Jason
jhawkeye
May 25, 2022 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
