Y06 9.5 inch ring gear?
Old Jul 15, 2008 | 01:49 AM
theorio1025's Avatar
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
what does this code mean?
Old Jul 15, 2008 | 01:51 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Y06 9.5 inch ring gear?
It doesn't mean you have a 9.5" ring gear.
Old Jul 15, 2008 | 06:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its probably from a heavy truck with a 14bolt, never in a thirdgen
Old Jul 15, 2008 | 11:30 PM
its on the rpo code list in the center console.
Old Jul 15, 2008 | 11:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
GM reused a lot of codes. It may have meant a 9.5" rear on one platform, but not on thirdgens.
Old Jul 16, 2008 | 09:28 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
yo6 from 82-85 is panel, cowl kick(carpeted)
yo6 from 86-01 is 9.50 diameter ring gear, saginaw rear axle
Looking at your info, you say that you have an 84 z. it's a safe assumption that you have the first one.
Cheers!!!
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
Irocguy01
Sep 28, 2015 02:03 PM
hectre13
Aug 26, 2015 08:17 AM
