any easy fix to 700R4 not holding 3rd gear at WOT?
My tranny always had this problem. Had it rebuilt, and it still has this problem. It has 3000 miles on it at this point. The only way around it is to back off the throttle slightly at around 5100 RPM and it will shift, then wait about 5 seconds, and get back on the gas. If I back off and immediately get back on the throttle, it kicks down to 2nd again, and by then it's into the redline.
91 Trans Am WS6
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
MoreMoodThatMod
91 Trans Am WS6
5.0 TPI auto
Trans Go shiftkit
MoreMoodThatMod
Mine is worse than yours it seems. I can run it up to the end of 2nd gear (80 or so with 2.73s), and then I have to back out totally. If I floor it again it slips back into 2nd. I can only run about 2/3 throttle in 3rd gear. Can you hold 3rd at WOT once its in 3rd?
EDIT: even after waiting 5 or so seconds It cannot hold 3rd gear.
How can you go to the track like this? Maybe your trans rebuilder didnt replace that clutch pack/
[This message has been edited by JeffP (edited October 03, 2000).]
Iroc8t8
Yesterday 02:06 AM
