Drivetrain vibration after installing poly trans and torque arm mounts
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
A few weeks ago I replaced the transmission and torque arm mounts with polyurethane units. After replacing the mounts, I've been getting an occasional vibration. It doesn't seem happen at any particular RPM, speed, or gear. The only time it doesn't happen is when it's in overdrive. It can be vibrating while I'm in D and when I put it into OD, it stops. Do the poly mounts just transmit more vibriation through the body, or did I just put it back together wrong? There weren't any vibrations with the old mounts before I replaced them.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Drivetrain vibration after installing poly trans and torque arm mounts
its normal to pick up some vibration with poly mounts. they dont absorb them as well as the mushy rubber ones did.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Thanks guys, that's what I was hoping to hear.
colton_carlson
Mar 8, 2019 12:21 PM
dhonda200
Aug 11, 2015 11:50 PM
