Alum Driveshaft
Old Oct 10, 2000 | 08:51 PM
Monkie's Avatar
Alum Driveshaft
I was wondering what you people that have an aluminum driveshaft would rate it as worth $329. Please give me some ideas cause Im thinking about putting it on my stock 92 RS as a mod. Please rate it 1-10. 1 being "hell no I would never do that mod again!" up to 10 being "thats some awsome mod!" Thanks!
Old Oct 10, 2000 | 09:43 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I would not spend the money unless you have some kind of problem with your current shaft, I would however spend the $150 buck it cost to get a used one, That is the average price.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 11, 2000 | 01:01 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The al 1LE only costs approx $230 new from Dal. I would rate it a 8.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Oct 11, 2000 | 10:07 AM
chevymike's Avatar
I would rate it a 8 as well. You really won't see a performance increase but if you have a bad vibration from around 75mph or above and you know your wheels/tires are balanced, you will find this will more then likely cure your vibration. I had a really bad vibration which is now gone. I have had it to 125mph and it is rock solid smooth.
BTW, I bought mine, new, from SDPC (board sponser) and they matched DAL's price. It also come with new U-joints and front yoke. L8R
Mike Schwartz aka chevymike
'92 Z28, 5.7, Teal Hardtop
"Don't Outlaw High Performance Cars,
Outlaw Low Performance Drivers!"
Mike's Camaro Z28
Old Oct 11, 2000 | 01:20 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I got mine from Dal also. But if SDPC is matching the price, so much the better. Support those that sponsor the board. I went with new for piece of mind. With a used one you may need to have it re-balanced and need new bearings. I rate it a 6, but would still do it again. I didn't experience the vibration problem and was hoping for a performance gain. I've only had mine to 103, and my RS is still pretty stock, engine wise.
Old Oct 12, 2000 | 10:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I still have a couple of used alum shafts, the 1LE variety, that have been offered but are as yet unsold. All are balanced, have the slip yoke, and reasonably good tubes. The rear U-joint caps are hit and miss--I'd suggest replacing anything. $155 shipped, money order, certified check, or PayPal. I've sold to many people on the board.
JamesC
Old Oct 12, 2000 | 10:14 AM
JamesC's Avatar
Originally posted by JamesC:
I still have a couple of used alum shafts, the 1LE variety, that have been offered but are as yet unsold. All are balanced, have the slip yoke, and reasonably good tubes. The rear U-joint caps are hit and miss--I'd suggest replacing anyway. $155 shipped, money order, certified check, or PayPal. I've sold to many people on the board.
JamesC
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
randy210
Oct 15, 2015 03:43 PM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
