5 speed swap question
Car: 1986 camaro z28
Engine: vortec 5.7
can i use the pedals and other accessories to a five speed from a 4th gen to accommodate a t5 in a 3rd gen?- its for an auto to a t5 swap
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 5 speed swap question
yes you can, though, IIRC the 4th gen setup has the gas pedal attached as part of the assembly. You cannot use the 4th gen pedal and it need to be removed. The geometry between the clutch pedal and the clutch master pushrod may be a little different, so i would recommend a 93-97 lt1 4th gen style hydraulic setup.
1992 Trans Am
Aug 8, 2015 08:16 PM
