Rear end
Old Oct 11, 2000 | 10:11 AM
SmokinZ28's Avatar
Rear end
Will 3.73 posi out of an 84Z swap with a 3.23 posi out of an 88 formula???
Old Oct 12, 2000 | 01:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The whole axle? Sure. If both axles have disc brakes, then re-use your '88's calipers, they're probably in better shape. Replace all the brake hoses and e-brake cables while you're at it. If you search the internet thru http://www.yahoo.com or similar for "carparts.com coupon", you can usually find some big savings. I used a $50 off $100 purchase coupon, and got all of my 86/3.42/open/drum to 84/3.73/posi/disc brake hardware for $60!
If your '88 doesn't have discs you need the prop valve and master cylinder for the J65 (4wheeldisc) setup.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 12, 2000 | 02:39 PM
SmokinZ28's Avatar
just the gears. the 84 has drums and the 88 has discs
Old Oct 12, 2000 | 03:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The 84 has drums? I thought the only 3.73/drum axle had an open diff, not a posi.
Old Oct 13, 2000 | 03:14 PM
SmokinZ28's Avatar
The gears came from another 84Z that had disc's originally
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
