How do I find Gear Ratio??
Old Oct 13, 2000 | 11:35 AM
fast89's Avatar
I have a 89 Pontiac Formula 350 with the L98 but I would like to find out what the gear ratio in the car is. I can no longer see the sticker on the rear axle cover, but I do have all of the codes in the middle compartment storage area. What are the codes I am looking for??
Old Oct 13, 2000 | 01:24 PM
fast89's Avatar
Any answers????
Old Oct 13, 2000 | 02:12 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The code will either begin with GU or GW depending on if you have the 10-bolt or 9-bolt rear. GU2 is for 2.73 gears in a 10-bolt. I think there is something on thirdgen.org that lists all of the RPO codes. If not, they're out there somewhere on the 'net. BTW, G80 is for posi-trac.
Greg Westphal
'87 IROC 305TPI/A4
Old Oct 13, 2000 | 04:39 PM
ede's Avatar
ede
if you pull the cover you'll find the gear ratio stamped on the ring gear. it'll be like 11:41. thats 11 teeth on the pinion and 41 teeth on the ring gear. 41/11=3.73 or a 3:73 gear set.
-=ICON MOTORSPORTS=-
Old Oct 13, 2000 | 05:48 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
For an 89 350 its really easy to tell. If you have a single cat, you have a 9-bolt 2.77 ratio. If you have dual cats, you have a 9-bolt 3.27 ratio. No other rears were offered for 89 L98's.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
