Torque Specs for clutch/ tranny
Old Jul 16, 2008 | 02:33 PM
NW94Z's Avatar
Car: See Sig
Just wondering if there is one place I can go for all the torque specs realted to changing out a clutch. Not just the flywheel, pressure plate etc...specs but also specs for the driveshaft , bellhousing to block, tranny to bellhousing, torque arm etc...
I'd rather go to one source than have to sift and compile a dozen different threads.
Thanks.
Old Jul 18, 2008 | 04:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Torque Specs for clutch/ tranny
I doubt it
I don't really use a torque wrench for most of that though.. Just make it "tight". Go by the bolt size anyway.
All bolts with 3/8"NC threads are typically around 40ftlbs anyway.
516/"NC is about 25ftlbs or so... etc.
Use loctite on flywheel to crank, and pressure plate to flywheel.
Old Jul 19, 2008 | 12:51 AM
NW94Z's Avatar
Car: See Sig
Originally Posted by Sonix
I doubt it
Thanks. I managed to scrounge them all together. Took awhile but I've got em.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
