torque convertor lock up switch
Old Jul 23, 2008 | 06:29 PM
IROC86CAM's Avatar
Car: 86 IROC
have searched, but can't find lock up switch for 86 iroc. i do not want to put in a toggle switch. just new stock switch, any help? part number?
Old Jul 23, 2008 | 06:34 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: torque convertor lock up switch
There is a solenoid inside the transmission pan, next to the valve body that locks up the torque converter.
However, it is unlocked by the brake lights. If your brake light switch is not adjusted properly, or is stripped (mine was) it does not allow your torque converter to lock up or it will lock/unlock intermittently.
Good luck
TA
Old Jul 23, 2008 | 06:44 PM
IROC86CAM's Avatar
Car: 86 IROC
stays locked up all the time.
thanks
Old Jul 23, 2008 | 09:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There isn't a stock switch, it's controlled by the ECM.
BRoss99
Aug 10, 2025 05:08 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
