what carrier do i have???????
Old Oct 17, 2000 | 02:58 PM
spitfire350's Avatar
i have an 87 camaro and i have no idea what gear carrier it has. i think it has a limited slip but again i am unsure. but the rear is a 10 bolt 7.5. Is there a # on the rear that will tell me what i have and if so how can i check the #? Thanx for the info!
keep the stang's far behind u and the cops even farther
Old Oct 17, 2000 | 04:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Look on the front of the passenger side axle tube. There should be a three-character number/letter code stamped there. Scrape all the accumulated crude carefully to be sure you read it correctly. Haynes has the codes in their manual, or post the code here for someone to decode for you.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gord327
Oct 3, 2015 01:25 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
