Stripped Speedo cable Bolt
Old Jul 25, 2008 | 03:12 PM
Crazydave2005's Avatar
Hello, I was replacing the o-ring on the speedo cable the other day and I stripped the threads when putting the retainer back on, the bolt broke in there, I am wondering what the best thing would be to do, I was thinking about putting a heli coil in there but is there any way I can keep the hole the same size, like installing a new part?
Also is there a special type of O-ring to put in there it seems to leak alot and the next size up wont fit in there. (this was back when the bolt was fine)
Old Jul 25, 2008 | 03:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stripped Speedo cable Bolt
A Helicoil will keep the hole the same size.
Old Jul 25, 2008 | 11:07 PM
Thanks, Does anyone know if there is a special size of O-ring? Also Im not sure of the size of the Bolt.
Old Jul 25, 2008 | 11:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
O ring for what, around the speedo gear housing? Just get a new one from the dealer.
Old Jul 25, 2008 | 11:13 PM
Yeah the speedo gear housing, I tried a couple o-rings, one was too small and the other was too big and they were one size apart
evilstuie
Jan 9, 2020 08:29 PM
deracer
Apr 11, 2016 12:04 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
