vibrates sometimes, sometimes not
Old Jul 26, 2008 | 10:22 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
so when i get to about 80+ my driveline vibrates bad...but sometimes it dosnt just now i was cruising back home on the 805 north doing 85+ the whole way and didnt notice hardley any vibration what so ever, so what can this be? can a new tranny mount or bushing change this or effect this? if i can just fix this effing vibration ill be happier than ever now. anyone gone through any trial and error?
and yes i know about the alum DS im working on getting one, or getting the orig DS re balanced, if this is an effective way to the solution also...
Old Jul 26, 2008 | 10:29 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Re: vibrates sometimes, sometimes not
Try from a stop and give it gas. If you feel any vibration then it would be your tranny mount. It's an easy fix and the part to replace it are fairly cheap. Go with the polyurethane tranny mount.
Old Jul 26, 2008 | 10:30 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
like you said aluminum driveshaft balance wheels. not sure if a transmission mount will cause vibration like you are talking about tho.
Old Jul 27, 2008 | 11:38 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
are you saying put it in neutral and give it some gas? its only at high speeds and it does it bad sometimes, someitmes not.
well i want an alum DS but arent they like 800 dollars?? thats a good penny. how much does it cost to re-balance our stock ones? or is it even worth it? and im not worried about the wheel as of now, cuz i just ordered some chrome IROCS with wheels and should be here any day now....thanks for the input though guys.
Last edited by samiam91RS; Jul 27, 2008 at 11:39 PM. Reason: Automerged Doublepost
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
